Browse Forums General Discussion Re: start up costs for solar 2Apr 06, 2020 4:20 pm The cost really depends on what quality you want. I have found the solar quotes website good value . . . https://www.solarquotes.com.au/ The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: start up costs for solar 4Apr 06, 2020 5:25 pm Yep, depends on quality. But should average about $1 per watt. So a 5kW system would average slightly over $5,000. Not much more for the 6.6kW system, as it's a 5kW inverter (The expensive but, along with labour), with just a few more panels, which are cheap. But it also depends on location. Although there's a federal rebate, some states offer additional rebates. Especially Victoria, where a 5kW system is about $3,500 I believe. Difficult installations add to the cost a bit. Especially if you have shading, or require more than two orientations, as microinverters (which are more expensive) need to be used. Double storey roofs also add a bit to the cost. Whirlpool's Green Tech forum is a great place to post queries about solar. Including of you want advice about how to choose a system, or want thoughts on the quotes you've received. https://forums.whirlpool.net.au/forum/143 I looked into it a few years ago and my conclusion was to just build a carport that will support panels and get a system installed separately. The company I looked at had… 1 6481 I am not sure whether Perth has its own way of doing things in regards to this. Most of Perth has class A (sandy soil), except for some areas near rivers or hills. 2 13099 Looking to tile the facade pillars rather than rendering. Builder is quoting 2500$ laying cost for upto 10msq. The 2 pillars come to be 16msq. So laying costs are 5000$… 0 7548 |
