Browse Forums General Discussion Re: Mortar Defects 4Mar 25, 2020 10:31 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Mortar Defects 6Mar 26, 2020 7:25 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Mortar Defects 8Aug 09, 2020 1:30 am hello OP, what did you end up doing finally? Lodged a complaint case with Builder? Re: Mortar Defects 9Mar 02, 2022 8:36 pm It could be the acid used to clean the brick has sat at the base. Put a bead of silicon around base to reduce further erosion. HTH Jessie2019 Hey guys Does anyone know what the issue might be with our brick mortar? It’s only about 9 months old. It appears to be washing away at the base of our Brick pillars and house in some areas. It’s crumbles easily too. Many thanks! [img]https://forum.homeone.com.au/u/93938_1585022541.jpeg[/im Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ *All in my opinion only Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6842 1 9448 All 3 items listed are defects and are of concern. Please seek qualified independent inspector and/or legal advice for your state. 1 8175 |
