Browse Forums General Discussion Re: Footings and steel piers for Transportable.. help 2Mar 24, 2020 9:09 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Footings and steel piers for Transportable.. help 3Mar 25, 2020 9:10 am ![]() Hi Ianmc Welcome to the forum You would do better if you put up the image of the engineering plan and details (Delete the name) Moment Of Inertia Calculator You can always do your own calculations/proofs, show them to your engineer, and if he is satisfied then he will stamp your sections/details Cheers Chris Thanks the welcome.. so exciting to be an empowered OB. I have yesterday sent a bullet point detailed list of concerns to the Engineer.. as clear as possible. To their credit, they have acknowledged and have advised a response is eminent. Your advice is exciting and I will investigate that option of own calculations. Pending their reply will determine posting of plans that may yet be altered.. Thanks quick reply, really good. You could remove the centre pier and replace the beam/lintel with a larger unit that has the specification to span the entire opening. IMO, metal posts would look like a… 1 2515 I may be comparing Apples with Oranges but piers for my slab were much cheaper than this. Not sure, if the ones used for retaining walls would be any different. 6 1146 Piers should have been inspected prior to the slab construction. 3 864 ![]() |
