Browse Forums General Discussion 1 Mar 21, 2020 6:30 am Hi I have a question we just had a colourbond shed built and the builder forgot to install the insulation in the roof. I want it in as I’ll be working in there a lot, he will now have to remove and roll out wire and insulation one sheet at a time he told me. My concern is getting leaks and the roof not be as structurally sound I wanted to get other people’s opinions on this. Thanks Re: Shed insulation 2Mar 29, 2020 1:08 pm Shouldn't be an issue. If the structure is relying on the roof sheeting to stand up you have more problems than it not being insulated. To be clear the sheeting is not a structural component. I can't see why it should leak more. They will most likely reuse the existing holes in the sheeting to reattach the sheeting. If there is leaking they would have to fix it. Better than having it uninsulated. Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5629 Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 3565 DIY, Home Maintenance & Repair I'm in WA and our sandy soils make drainage a bit easier but this is what I'd be doing. Dig down to your footings and let the wall dry out. Clean it all well by brushing… 1 5389 |
