Browse Forums General Discussion 1 Mar 21, 2020 6:30 am Hi I have a question we just had a colourbond shed built and the builder forgot to install the insulation in the roof. I want it in as I’ll be working in there a lot, he will now have to remove and roll out wire and insulation one sheet at a time he told me. My concern is getting leaks and the roof not be as structurally sound I wanted to get other people’s opinions on this. Thanks Re: Shed insulation 2Mar 29, 2020 1:08 pm Shouldn't be an issue. If the structure is relying on the roof sheeting to stand up you have more problems than it not being insulated. To be clear the sheeting is not a structural component. I can't see why it should leak more. They will most likely reuse the existing holes in the sheeting to reattach the sheeting. If there is leaking they would have to fix it. Better than having it uninsulated. Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4899 Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some… 2 5417 Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 3428 |
