Browse Forums General Discussion 1 Mar 18, 2020 3:08 am Hi, I’d like your opinion. Am I being too picky in thinking this is a complete and utter bad job?! Can you tell me what you see is wrong with this? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Bad job decking 2Mar 18, 2020 9:20 am That is not a good job. The spacing between the boards is all over the place. It looks more like the sort of job I'd expect from a DIY'er than a professional. If what you can see is built with that little care I'd be concerned that the subfloor that you can't see is even worse. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Bad job decking 3Mar 18, 2020 1:24 pm Looks bad to me, I'm a DIYer and would not be happy if I had done that (then again I just built a pergola and it is heaps better than a similar one that was done by a "professional" next door) Are those pen lines all over? Screws are all crooked as well Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10973 Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7042 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10412 |
