Browse Forums General Discussion 1 Feb 26, 2020 10:20 pm Re: Building duplex over or near water or sewerage pipes or 2Mar 01, 2020 7:43 pm Yes you can but Sydney Water will make you excavate the existing VCP main sewer ( old earthenware pipe ) then concrete encase it @ $1,100 a lineal metre ( with a few other caveats too ). Stewie As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5727 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10808 Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11033 |
