Browse Forums General Discussion Re: Stormwater issue 2Feb 27, 2020 7:38 am Isn't this the same issue as in you other post? Anyway, you need a solicitor, not a public forum My understanding is that it should not have have the final approval for sub division and be titled if the appropriate works were not carried out. Especially since LPOD is managed by Council and they would have had to inspect the LPOD build. Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4835 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8454 in the stormwater pit or the drain? Those dont look like theyd fit in the drain. Separately, the pits do get stuff in them during the course of the build. For the most… 1 7928 |
