Browse Forums General Discussion Exterior house colour advice Colourbond Gully 5Feb 21, 2020 1:59 pm I found this picture of a house which has colours that I think would work well for yours. The roof is "Gully", and the walls are white, but you could use an off-white. You could find a place to use "Ground Pepper" (from the palette above) as an accent, and paint your front door "Pumpkin Pie". I know living in a semi-rural location the tendency would be to avoid white, but we live in a fully rural location and we have white (Colorbond "Surfmist") everywhere, and I've found it’s often the dark colours around our place that show up the dirt more than the light ones. Besides, suburban locations are often much more dirty than rural ones because of all the car exhaust and tire dust. Like ⋅ 1 comment ⋅ Pin to Ideaboard ⋅ Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6249 Yes i guess this is one of the main reason as i checked one post foundation 4 9997 Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 8512 |
