Browse Forums General Discussion Re: Driveway standards and issues. 9Feb 05, 2020 9:34 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Driveway standards and issues. 11Feb 10, 2020 7:11 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Driveway standards and issues. 13Feb 10, 2020 7:37 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Driveway standards and issues. 15Feb 10, 2020 7:41 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Driveway standards and issues. 16Feb 10, 2020 7:42 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Driveway standards and issues. 17Feb 10, 2020 8:24 pm We didn't have one done as we are having a deck entrance built leading up to the front door from the foot path. Re: Driveway standards and issues. 18Apr 21, 2020 12:51 pm Just the other day the driveway has cracked all the way through and all the way across to the other side. I am now concerned to even use the driveway in anyway. It is defiantly not 100mm think and has raised completely out of the ground. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Driveway standards and issues. 19Sep 05, 2020 4:15 pm We have not had a report done and it appears there are several issues. Driveway poured at 65-70mm. Lack or ableflex against driveway and garage. Driveway must be designed to access the garage. Now we need to take the concreter to VCAT to get some form of resolution. Re: Driveway standards and issues. 20Sep 06, 2020 7:15 am Your local council would have guidelines which are based I think on an Australian standard for egress and access. You should be able to download them and compare them to yours. That's what we have to do when we lodge a DA through our council. I'll post up some later.
As per your drawing, he hasn't incorporated a transition zone which basically reduces the harsh angle from driveway to garage and it is both easy to work out and to do. He is just lazy. Stewie Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7005 I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 5152 2 8645 |
