Browse Forums General Discussion Re: Bracing timber beam under house 2Feb 02, 2020 8:53 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Bracing timber beam under house 4Feb 03, 2020 7:44 am HopHead I'm happy to get the correct trade involved in getting this fixed, but given it is the original structure, I wouldn't imagine Council would need to get involved if we go down the path of bracing/stiffening? Also I'm not sure what you mean about the stud wall supporting joists? All joists are firmly sitting on a beam. Correct, the council will ask you to engage a private Building Surveyor (BS) as they don't always inspect retrospective approvals or similar. The BS checks the build against the NCC if the construction is as per the codes it is compliant no further action is taken, if not, it's non compliant and he will advise you to engage a Structural Engineer and then certify the engineers report, details or rectification,etc. In WA that's $300+ for the BS stamp and $300 for the engineer site visit.. OT you can check the codes yourself here National Construction Codes anything not in the codes I suggest you talk to an engineer and get his signature/stamp. Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi all, Not sure if this is a good place for this question but I guess we'll find out! I'm a novice, building a modular room inside my garage/shed and need to create… 0 1850 Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12867 |
