Browse Forums General Discussion 1 Feb 01, 2020 2:00 pm I live in a caravan park in a joined caravan/annex. There's one double power point in the caravan and I wish to have 2 double power points installed in the same wall but on the annex side. The distance along the wall from the caravan power point to the 2 new power points will be 1 and 3 metres. Can anyone tell me how much this will cost? Do electricians give aged pensioner discounts? Thanks. traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 4211 If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13846 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15791 |
