Browse Forums General Discussion 1 Jan 29, 2020 3:37 pm Hello All I know this topic has been discussed at length but I would like to describe my particular situation and get some thoughts from the experts on here. I have a 100 year old single story double brick house on the upper north shore of Sydney and in winter the house gets very cold. We have put new insulation in the ceiling and under the timber floor (we have a crawlspace) an it did not have a noticeable positive effect. I would like to also replace the old single glazed timber windows too. I then purchased a thermal imaging camera (this was back in august) and that provided an interesting insight. By far the coldest surfaces - colder than the windows - was the inside of the external double brick walls, just above the skirting boards - from memory it was 10 degrees (and this was while the heating was on and set to 18 degrees in the small bedrooms). This has got me looking at blow-in insulation - rookwool etc - such as companies like Just Rite do in Sydney. Am I on the right track? Is there anything else I can do such as something in the crawl space? Any advice based on facts and\or experience appreciated! Re: Old house with cold double brick walls 7Feb 17, 2020 8:26 am Stewie D Do you also have the internal vents high up close to the cornice in external walls ? Stewie Not any more... I blocked them up on the inside years ago as all the heat was escaping there in winter. Re: Old house with cold double brick walls 8Feb 17, 2020 9:18 am Good idea. Apart from the walls there is not much else you can do seeing as you have the ceiling and floor insulation taken care of. What R rating are they both and did you install them or get someone else to do it? The reason I ask is that I've seen a few jobs in the past where companies have been employed to do it and the end result left a lot to be desired - gaps in insulation between joists, not taken all the way out to the top plate etc. A 5% gap results in 50% less effective insulation. Stewie Re: Old house with cold double brick walls 9Feb 17, 2020 2:17 pm Interesting.... I got both floor and ceiling insulation professionally done but I can see with the thermal camera that there are gaps here and there in the ceiling. The cornices also seem to be an area that lose heat (or lets it in in summer) Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 9956 Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 12664 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 2603 |
