Browse Forums General Discussion 1 Dec 29, 2006 8:28 pm O,K gurus need some advice. We are going to knock down an old weatherboard to build our dream home. Problem is, we would like to switch the driveway to the otherside of the house (best left explained elsewhere) but the existing water meter is located on that side. Is it possible to have it repositioned, say a few meters over to one side so we can put in a driveway? I'd imagine a permit from melbourne water and a licensed plumber should be able to do the trick?
Any advide would be greatly apreciated. Re: Re-positioning water meter? 2Dec 29, 2006 10:17 pm You're spot on. Get the plumber first and he'll give you all the details re permits etc. If he's on the ball he might even save you the trouble and arrange all the permits etc for you. If all you can see are obstacles, you have lost sight of the goals Should be something they come out ASAP to rectify, looking at the neighbors it would appear yours has a leak as I would expect theirs also to be filled if it was seeping… 2 3156 Thanks for sharing. Looks good. The joiner has come back with a quote of close to 5k. I think we are going to not do it. Attaching panelling is something they are dead… 11 6249 you can also look at fresh water chlorine generators. they still require salt, but it's 1200ppm or so, instead of 5500 for traditional salt water pools, or 2500-3000 for… 2 4925 |
