Browse Forums General Discussion 1 Jan 17, 2020 10:28 am Our builder has deleted the alfresco waste point and the reason they are saying is the point of discharge for the storm water is too high and by the time the pipe work gets to that area its not far enough below the surface and affects the integrity of the slab. Did anyone experience something similar to this. Just wondering about the consequence of this deletion. Re: Our Builder had deleted alfresco waste point 2Jan 18, 2020 7:41 am chezhianrv Our builder has deleted the alfresco waste point and the reason they are saying is the point of discharge for the storm water is too high and by the time the pipe work gets to that area its not far enough below the surface and affects the integrity of the slab. Did anyone experience something similar to this. Just wondering about the consequence of this deletion. This sounds like an isolated event, there are two things the builder cannot change. 1. The point of discharge - location council nominate for the storm water. (Street, laneway, drain) 2. The grade in the drains. Pipework needs a min fall for it to be compliant. This will determine the height and if the pipe is above the slab well obviously that won't work. Do you have a plan to check out? MC Registered Building - Always happy to help where I can and simply loves the game. DM me if you need help in VIC. Re: Our Builder had deleted alfresco waste point 3Jan 18, 2020 7:57 am The solution could have been to raise the House fill and slab above the ingress invert POD This should have all been checked during the stormwater design stage Please check with your Council Building Dept Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Our Builder had deleted alfresco waste point 4Jan 18, 2020 8:21 am StructuralBIMGuy This should have all been checked during the stormwater design stage I would be priority checking the slab levels. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. That is a really good attitude Akin to you catch more flies with honey than vinegar. I do enjoy watching that tik tok inspector from Victoria but he does go a little… 12 81884 Building Standards; Getting It Right! Hi All, We have a fall from road to garage front. But we cannot put a drain/grate because no discharge point put by the builder. Now they complain not enough space for… 0 9242 Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6524 |
