Browse Forums General Discussion 1 Jan 06, 2020 8:54 pm Dear All, Looking for an expert opinion from you. I originally decide to have facade part render and brick work over garage. No after seeing few display homes, decided to go with facade full render. However, it is noticed that with the full render at the display home I saw, they have kind of visible joint apparently making me feel that it has fiber cement sheet and not brick over the garage. As per developer requirements brickwork over the garage or render over the garage is mandatory. Brickwork over garage costs $1750 and render would be additional. Is there a need to have brickwork over the garage when the complete rendering is done? Aesthetically and structurally what is the best option? Like the best to avoid cracking etc. Fiber Cement sheet + render ( cheaper ) or Brickwork + render ( costly by $1750) - just worried whether spending extra will not have any effect as it would get buried underneath. Could you please provide your suggestions. Below is the photo of the render from display home Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks in advance Re: Going with full render - do brick work over garage need 4Jan 07, 2020 7:05 pm Hi ssyi Why cheapen your facade with a rendered pelmet that will probably vibrate with the opening and closing of the garage door? Structurally it is better to tie the nibs to a t bar and brickwork above Cost of a T-bar ($200) + brickwork ($200) ≠ $1750 ? Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Going with full render - do brick work over garage need 5Jan 08, 2020 2:37 am Thanks a lot Chris. Sorry to ask noob question. Is T-bar part of brickwork over garrage as a standard. My builder do not provide me these kind of information rather than charging me $1750 for brickwork over garage. I assume it would not something achievable post handover. So right now the best option would be to have thw brickwork over garrage ($1750) and then render (probably another ripoff $ figure for render) ? Thank you. Re: Going with full render - do brick work over garage need 6Jan 08, 2020 9:04 am Sorry, structural lintels can't be added in after handover That's a price comparison you should have got before you handed over the deposit, now it's hard to negotiate any reductions on price as the builder charges extra and in many cases gouges back extra profit. I can't stress how important it is to know how trades are priced up so that you can make informed decisions on the opposite side of the equation the builder is entitled to a fair profit so use this knowledge wisely and negotiate fairly Generally there is no extra charge by the plasterer over openings Openings aren't deducted in the initial pricing, it is calculated as a gross area ie Brickwork (m2) + Windows (m2) = Plastering (m2) alternatively it's approximately a m2 of brickwork above the lintel (plastering $20/m2) hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 740 I recently hit a snag with my new build with Metricon. On the block I purchased there is an old covenant when the land was subdivided in 1971 that "the exterior walls of… 0 1133 Cheers. The painted render is a bit chalky to the touch. To prepare the surface for best adhesion, what would you recommend? Also, given that there must be some… 6 1617 |
