Browse Forums General Discussion Re: Electric Toilet- prerequisites/considerations for new bu 3Jan 03, 2020 6:47 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Electric Toilet- prerequisites/considerations for new bu 6Jan 03, 2020 10:45 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Electric Toilet- prerequisites/considerations for new bu 9Jan 03, 2020 1:19 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Electric Toilet- prerequisites/considerations for new bu 11Jan 03, 2020 2:28 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Electric Toilet- prerequisites/considerations for new bu 13Jan 03, 2020 3:22 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Electric Toilet- prerequisites/considerations for new bu 15Jan 03, 2020 4:48 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Electric Toilet- prerequisites/considerations for new bu 17Jan 03, 2020 6:14 pm Shi .....but as you know once we sign the contract the ball is in their court and if possible they would charge me for my own breathing ! Welcome to the Australian building industry. I hope that your build goes well. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Electric Toilet- prerequisites/considerations for new bu 18Jan 03, 2020 7:30 pm SaveH2O Shi .....but as you know once we sign the contract the ball is in their court and if possible they would charge me for my own breathing ! Welcome to the Australian building industry. I hope that your build goes well. Hoping so ! Thanks for all the support from you and all the others in this forum. This forum gives lot of confidence that the help is just on the corner Re: Electric Toilet- prerequisites/considerations for new bu 19Jan 19, 2020 9:00 pm From what I've read, Melbourne's recycled water can have elevated TDS (Total Dissolved Solids). Electronic bidets contain a water heater, small pump, small solenoid valves, small water passages and servo controlled telescopic nozzles. All of these are susceptible to scaling and should not be used where water has high TDS. Doing so will reward you with premature issues of your units. If mains water is plumbed to the toilets' vicinity but only connected to the bidets, mains water consumption should be very low. I own an iZen IB-7500 and measured it's water use to be between 50 and 200ml per use depending on the selected pressure and how long you need it to operate. At worst 25 uses will be equivalent to one flush. I for one think they are totally worth it, in paper saving, comfort and cleanliness. Just activate power saving if it has it so it doesn't burn power while you're not using it and be wary of what a heated seat can chew up in power if it's too high or not necessary. This is separate to the issue of potential bacteria in recycled water. Recycled water is generally not a problem (bacteria wise) cold out of the tap. It is potentially an issue when the few remaining bacteria are left to multiply at elevated temperatures as found in the bidets water tank, hence the guidelines advice. Re: Electric Toilet- prerequisites/considerations for new bu 20Mar 04, 2021 5:05 pm Shi SaveH2O Shi .....but as you know once we sign the contract the ball is in their court and if possible they would charge me for my own breathing ! Welcome to the Australian building industry. I hope that your build goes well. Hoping so ! Thanks for all the support from you and all the others in this forum. This forum gives lot of confidence that the help is just on the corner Hi Shi, Could you share what did you ended up doing? I am building in Melbourne west and in the same dilemma since I am on verge of signing my building contract. My builder has denied the request for giving fresh water supply to toilets and is even reluctant to add a fresh water tap close to toilets (which can be used in future to install bidets) saying developer might not approve it and even if they do just adding a tap there will cost upwards of 3k since it will include water proofing the wall and what not (even though washbasin vanity is present in the same bathroom). Thanks! Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 13622 "Losers" "humanity" "off time" "your" "top notch" "love symbol" Sounds like ponzo is done using other people's toilets 36 23832 Hi everyone! This is my first time posting here, and I'm looking for some advice regarding my house construction project in North Kellyville. I… 0 6693 |
