Neighbours slab higher than my house
If it's on his land,he will pay and can't let run off water go into your property,or you could place on boundary and go halves,would probably mean less run off into your slab.
Thanks
.......my neighbour slab is higher than both the adjoining houses. I am worrying about if this needs a retaining wall and if do then who is bearing its expense.
It depends on what the natural ground levels were and who altered what.
wasnt impressed but didnt know what could be done so went ahead and built a retainer wall,but still get heaps of water with heavy rains from next door.So next step is concrete pathway with lots of drainage.All because of the builder not having any consideration.or the owners for that matter.
You needed to make proper enquiries at the time. The retaining wall needed to be on their side.
Stewie
Thank you where would you go to get this information thanks.
13
interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing…
3/12/2023
4
The only thing to add to these comments is that where possible it's always good to try and work with people than just say "no" because you can. Having someone…
13/06/2023
1
it depends on the natural ground level, if they excavated their boundary wall needed to be built as a retaining wall. If you filled, which sounds like the case then you…
