Browse Forums General Discussion 1 Dec 01, 2019 9:53 am Hi guys, I have a load bearing wall to remove but it is now a bit confusing with the references in the internet to say it would require permit and building surveyor etc... and a renovator to say no need anything at the moment to remove it except for a builder certificate or something like that. I am in Melbourne. Any advice would be very much welcome. Also if you guys know a service or build who could help with the work, please send me PM. Many many thanks. Re: Load bearing wall removal 2Dec 02, 2019 10:32 am You will need a building permit, removal of load bearing wall is a structural alteration A registered builder will not give you any certificate unless there are rocks in his head and it would be worthless anyway If your job is worth doing, pay the price and get it done properly. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Load bearing wall removal 3Dec 03, 2019 8:48 pm Thank you building-expert. I could confirm that. I called the council this morning to ask the question and their answer was that they are not doing any permit thing anymore but a building surveyor will. I then contacted a building surveyor and they said the same thing as you. Definitely need a permit for removal of load bearing wall. The interesting thing is that the building surveyor would then send a copy of everything to council if i go ahead and finish the removal. Re: Load bearing wall removal 4Dec 04, 2019 4:27 am I am glad I pointed you in the right direction and wish you well with your alteration. By law building surveyors are required to forward a copy of building permit drawings to the council for records only, however there is no secondary assessment other than cursory review. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Load bearing wall removal 5Dec 04, 2019 4:38 am Put simply the council do not have the expertise and resources to inspect all build sites with non compliant structures/alterations and require external Building Surveyors to fill the gap, in turn they rely on Certified Structural engineers reports and details. Council Extract for Building Applications (BA) WA "...Structural Engineers Certification Details are required for all steel and masonry structures by a Practising Structural Engineer, which must including: site classification, footing details and wind loading. Further information may be required, this will be determined upon assessment" The rules have tightened as a result of poor building practices and recent near building collapses, ie opal towers, mascot towers,etc..... Renovators, Carpenters and Builders aren't able to certify anything structural. Carpenters and builders aren't necessarily happy either here Roof Support want to remove some walls hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 4127 DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6335 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6711 |
