Plumbing washing machine into rainwater tank?
I've been thinking about plumbing the waste pipe from my washing machine into our rainwater tank. If I only use the tank water for the lawn and toilets, does anyone see me having an issue? The only one that comes to mind is whether or not the washing machine pump is strong enough to pump the water high enough to into the tank.
Thank in advance!
But - we just had a pipe from the machine to the spot we wanted - garden/lawn/whatever. Often you don't want it directly on the thing - maybe to a hole nearby - eg for a tree.
Hi all
Thank in advance!
Thank in advance!
Real bad idea.
You cannot store grey water for more than 24 hours.
The washing machine pump is not suitable.
Just use the final rinse on the garden and also plumb more downpipes to the tank but make sure that the tank is not in risk of overtopping during heavy rain.
The problem. Our Climate. Due to lack of constant rain turnover, tank water would go 'stale' and leave people's clothes with a nasty after smell. We had to abandon it and just leave the tank for the lawns.
We had our communal laundry use the rainwater tank that switched over to the normal water when the water got below a certain level in the tank.
The rainwater harvesting system was obviously sub standard.
If a rainwater harvesting system is competently designed and plumbed, the water will be sweet and not become anaerobic. Unfortunately, most (I estimate +95%) water tank installations are sub standard (and overpriced).
Hey all Currently renovating our laundry, bought a new washing machine but have found that the drainage hose is alot shorter than the old machine (which I used to get the…
23/05/2023
3
But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.…
9/11/2023
7
Grate, thank you! RexChan if thats the reason i could sleep well without thinking about additional cost. But 1st i'll need to read about NRV cleaning/replaing stuff. I…
