Browse Forums General Discussion 1 Nov 10, 2019 4:09 pm Hi anyone know if Builders match quote price ,comparing between matricon and Clarendon, at this stage matricon is 15 grand cheaper than Clarendon with all upgrades and even giving bigger aircon and solar,they both covering almost same area , we are in Qld , any advice will be appreciated Thanks Re: Metricon vs Clarendon 2Nov 10, 2019 4:44 pm Unless it's exactly the same plan,hard to compare as homes vary in cost big time depending on many factors in which some are not obvious such as roof line,the boxier the shape the cheaper it's likely to build,frame quality and timber quantity used,inclusions really should come on the lower level of importance has they don't cause building problems which can make a new home life changing for the worst, unfortunately most will have these in the wrong priority almost giving poor quality building practices a lifeline,consider first second third who builds the better quality house , trouble free as possible. Re: Metricon vs Clarendon 3Dec 08, 2019 10:56 am Ask for per square build price with same type of frame and slab material. Then compare for base house price. the stair balustrades? There is nothing special about these and I imagine literally every stair installer will be able to do this. 1 6736 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7857 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10749 |
