Browse Forums General Discussion Re: Split level home 2Nov 08, 2019 7:43 am Hi Shan_Brad Welcome to the forum Sure you can go to a builder first but if the builder draws up the floor plan they will own sketch/copyright and you will be unable to shop the plans around for the best price? On difficult blocks it is advisable to have your own preliminary, contour survey, sketch, engineering and approximate quants to start with before you engage 3 builders. Here's why 1. You deal with a Sales consultant (on 3-5% Sales commissions) whose job is to get a cash commitment, they are not experts and prone to making errors, I suggest you put them to the test,nuf said 2. Avoid designers with sweet heart deals with selective builders ( on 3% design fees + Sales commissions), you may think you are getting a good deal, but unless you have quantities and approx costs provided you will never know, because you will be unable to scrutinise the construction/engineering costs 3.On difficult builds, designers/builders always leave the engineering til last... It's money for jam in VOs for builders gouging 4.Shop around 2% of the build price is a far price for preliminary design, engineering and quants/costs. 5.Once with have all the data and information in 4. above get all builders to sharpen their pencils, BTW building activity is coming off the boil/boom so it's a great time to build-> low rates and material prices, fast build times , choice of better tradesman, etc Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Move your linen into laundry and access laundry from your present linen space 1 8014 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17527 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6595 |
