Browse Forums General Discussion 1 Oct 31, 2019 10:36 am How much does it cost to get a standard painter to come paint your standard size bathroom π½. Dimensions are 3.6metres long and 1.9 meters wide.. If you DIY how much would it cost. How many days does it take to complete a paint job of a bathroom? Re: Bathroom painting costs π¨ 3Dec 05, 2019 8:38 pm Steve500 How much does it cost to get a standard painter to come paint your standard size bathroom π½. Dimensions are 3.6metres long and 1.9 meters wide.. If you DIY how much would it cost. How many days does it take to complete a paint job of a bathroom? That doesn't look good, I wouldn't imagine you wouldn't get out of that any cheaper than 1000-1500, Even if the peeling bit comes off easy the area that has plaster under it will be very hard to strip back and you will need some plastering, sealer and two coats Low sheen. There would be at least two days involved. Hope that helps. Re: Bathroom painting costs π¨ 5Dec 27, 2019 9:25 pm High risk other areas of paint will delaminates as you roll a coat on that ceiling. Low sheen is best but I would try one of the Dulux Wet area ceiling paints which are a βflatβ finish which will hide plastering work. Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can itβs already a more thinner product than a final coat paint Also in water base Water or… 3 5025 Thanks mate, is there a standard off the shelf type breathable product I can apply DIY? Thanks 2 8214 |
