Browse Forums General Discussion 1 Oct 19, 2019 12:28 pm Hi , We live in NSW and want to add a granny flat in our backyard. I want to know about the steps which are involved in this process. From where we can start it. I mean from council permissions to building etc. Please share your experience or suggestions with me . Thanks Re: Granny Flat 2Oct 20, 2019 4:27 pm Adam007 Hi , We live in NSW and want to add a granny flat in our backyard. I want to know about the steps which are involved in this process. From where we can start it. I mean from council permissions to building etc. Please share your experience or suggestions with me . Thanks Hi guys , I am still waiting for your reply . I am happy to provide further information regarding block and existing building. Thanks Granny Flat 3Oct 20, 2019 5:03 pm My neighbours added a granny flat to their backyard. They got quotes, decided on a builder, and I believe the builder dealt with the permits and council approvals etc. We have a granny flat included in our new build, but it’s attached to the main dwelling, so not quite the same situation as yours. Re: Granny Flat 4Oct 20, 2019 9:16 pm I haven't looked into it for a few years OP, so things might have changed. But as long as the granny flat meets certain requirements, then you only need "complying developer", which is much simpler than the usual DA process. Some of these requirements are a minimum block size of 450sqm (with a frontage of at least 12m), & a maximum granny flat size under 60sqm. Re: Granny Flat 5Oct 21, 2019 5:31 am ddarroch I haven't looked into it for a few years OP, so things might have changed. But as long as the granny flat meets certain requirements, then you only need "complying developer", which is much simpler than the usual DA process. Some of these requirements are a minimum block size of 450sqm (with a frontage of at least 12m), & a maximum granny flat size under 60sqm. Thanks for your reply, Please have a look the following photos of my hour plans. I want to build granny flat on right hand side of the house. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Granny Flat 6Oct 21, 2019 7:26 am Adam007 ddarroch I haven't looked into it for a few years OP, so things might have changed. But as long as the granny flat meets certain requirements, then you only need "complying developer", which is much simpler than the usual DA process. Some of these requirements are a minimum block size of 450sqm (with a frontage of at least 12m), & a maximum granny flat size under 60sqm. Thanks for your reply, Please have a look the following photos of my hour plans. I want to build granny flat on right hand side of the house. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Sorry for typo , the word is floor plan and we want to add granny flat on left hand side of existing building. Thanks I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4106 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13880 Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 7209 |
