Browse Forums General Discussion 1 Oct 17, 2019 9:37 pm Hi Folks, Im planning to setup outdoor camera has 4 camera provisioning already setup. im thinking to go with budgeted outdoor camera with wireless indoor camera in same brand company. My known friend advise to buy Dahua 8CH 8POE 6MP Motorized Zoom Bulit-in MIC Camera which has 4 camera thats it. And have no option for wireless indoor camera to setup with this dahua brand. Can you kindly assist me good and affortable 4 camera for outdoor and 3 camera (wireless) for indoor area. please assist. thanks. Re: camera for outdoor and indoor in sydney 2Oct 18, 2019 2:42 pm I assume you are planning for POE external camera? I would recommend to purchase an 8 channel NVR, so you can connect upto 8 camera (outdoor, indoor, POE ethernet or Wifi). Do you already have any NVR? The Dahua you mention should be able to support the 3 indoor wifi as well....as long as they are compatible (ONVIF) When buying any equipment, ensure that it supports ONVIF protocol. If the equipment supports H.265 encoding, then that will be great...however this is not a must have as H.264 and H.264+ are good+. IMO you do not need camera with motorized zoom for home usage. What is your intended use/placement for indoor camera? I recommend VIP Vision products as these have local warranty & support. One reseller is https://www.rhinoco.com.au/category/read/1/cctv-surveillance-systems Also check out their Youtube videos. VIP vision is for NVR and POE camera. Your indoor camera will depend upon your needs....so more on that later. Re: camera for outdoor and indoor in sydney 3Oct 19, 2019 8:11 am Hi IamSAM, I dont have any NVR, by the way waht is NVR. Just 4 wiring connection provided by wiring man. , i would like to keep 3 camera inside house as i plan to rent one room as i and my partner go for work only my mother in law at home what to manage what is happening inside my house. so thinking to keep three camera to cover inside home. but inside no wiring has been done ,so i was planning to setup some wireless camera. planned to go with same brand so that i can manage all camera in one portal to view in my mobile. please share me good one to satisfy all needs. Thanks for your kind replay. Re: camera for outdoor and indoor in sydney 4Oct 21, 2019 7:42 am NVR = Network Video Recorder. The 4 wiring in your house must be coming together at one place and this is where you will place the NVR. The NVR will also require 1 wired connection to your router. NVR has a hard disc that will record the camera feeds. If your wired camera are POE then the NVR needs to be POE capable to provide Power Over Ethernet to the camera. If no POE then your wired camera will require power connections. With 7 camera, you will need a hard disk of 3TB or more to have at least 2 week video footage. The wifi camera should connect to same home network that connects the NVR. In this way you can access wifi camera via same App (as the one used for wired camera). If your NVR cannot support 7 camera (NVR support 4 or 8 or 16), then the wifi camera will have to be accessed by another 3rd party App. Check out VIP Vision brand. Re: camera for outdoor and indoor in sydney 5Oct 30, 2019 8:18 am IamSAM NVR = Network Video Recorder. The 4 wiring in your house must be coming together at one place and this is where you will place the NVR. The NVR will also require 1 wired connection to your router. NVR has a hard disc that will record the camera feeds. If your wired camera are POE then the NVR needs to be POE capable to provide Power Over Ethernet to the camera. If no POE then your wired camera will require power connections. With 7 camera, you will need a hard disk of 3TB or more to have at least 2 week video footage. The wifi camera should connect to same home network that connects the NVR. In this way you can access wifi camera via same App (as the one used for wired camera). If your NVR cannot support 7 camera (NVR support 4 or 8 or 16), then the wifi camera will have to be accessed by another 3rd party App. Check out VIP Vision brand. IamSAM thanks for your kind reply. as i checked in VIP vision brand in google it shows AV Australia https://www.avaustralia.com.au/enquiries/ is those people can help me to sort our wifi camera and wired camera outdoor. please confirm. Re: camera for outdoor and indoor in sydney 6Oct 30, 2019 10:21 am You should start with contacting local companies who install ALARMS & SECURITY CAMERA. They will be able to give you good service. I am in Southwest Sydney and got mine done from Harding Security. Re: camera for outdoor and indoor in sydney 7Oct 30, 2019 8:06 pm IamSAM You should start with contacting local companies who install ALARMS & SECURITY CAMERA. They will be able to give you good service. I am in Southwest Sydney and got mine done from Harding Security. Hi Iamsam, im also from same location , nice to know you would be my neighbour. thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1683 Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5877 which 1) PoE based video intercom is best for two storey home. I am looking with two monitor, one in GF and another FF so someone in home can… 0 24958 |
