Browse Forums General Discussion Re: Are holes in brick mortar normal after acid wash? 3Oct 15, 2019 8:18 am Newbie2334 Welcome to the forum, photos safe guard you in the future and also help others on the forum You will need to have the wall inspected and certified by an engineer mortar problems are a defect, also rendering the wall is not a remedy. Basically, render is not a structural component. refer to AS3700 Masonry Structures In a nutshell,it's either as per the codes or solutions are required to be equivalent or better than... Here, data and proofs are now required in the New NCC Development Of Performance Solution and Evaluations hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Are holes in brick mortar normal after acid wash? 4Oct 15, 2019 12:53 pm Newbie2334 Hi all, first time home builder here. We are building a single story brick veneer home in Sydney. The brickies recently finished laying the bricks and did the acid wash last week. Today when I went over to inspect the finished product, there are holes here and there in between the bricks, which looks as if some of the mortar has been washed out and also noted a couple of horizontal hairline cracks. Is this normal after the acid wash stage? When I stick my hand through the holes it’s not sandy and solid. Is this normal and will this be rectified before we do handover? Not sure if this is something I need to raise with the builder now (they are up to plastering stage now) or this is something they will inspect and touch up before they hand over our keys? Can’t see any specific clause in the contract. Thanks, any input would be appreciated. Yes it's normal after acid wash and usually good buidlers will patch them up. And it's not sandy usually it's good. |
