Browse Forums General Discussion 1 Oct 09, 2019 8:33 am I have an 80's built 2 storey home with a concrete slab upper floor. The slab is supported by metal beams running all the way from one side of the house to the other. I want to remove an internal single brick wall that I don't think is weight bearing; but want to be sure. No-one seems to be sure and I can't find anything online. Re: Concrete upper floor 2Oct 09, 2019 10:08 am What qualifications did the persons you asked have? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Concrete upper floor 4Oct 09, 2019 1:01 pm I've removed some of the cornice and can see at the top of the brick wall where a half-brick has been laid to meet the steel beams. So to me it looks like the internal brick wall was added after the upper floor was constructed and shouldn't be a supporting wall. Re: Concrete upper floor 5Oct 09, 2019 1:30 pm I'd ask a structural engineer. My build with Inspired/ Como Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=93656 Re: Concrete upper floor 6Oct 09, 2019 1:36 pm ben888 I'd ask a structural engineer. Ditto. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16555 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 |
