Browse Forums General Discussion 1 Oct 03, 2019 10:03 am Hi all. I have a Rheem external hot water system. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Installed in Feb 17 as part of a new house and since the start of the year the relief valve has been leaking/dripping drops of water. I thought it was to do with the heat during summer as read that could be the case, but it is still leaking and dripping over winter. Video of the leak is here https://youtu.be/iCqSVCjbeps Does anyone know what the problem is? I've got the Rheem guys coming in the next few weeks but wondering whether it is something simple I can fix? Re: Leaking relief valve from hot water system 2Oct 03, 2019 10:09 am Have you tried opening it a few times. If a bit of scale gets stuck in the seat they series seem to leak a bit. If you open the valve a few times to flush it out I've found it helps. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Leaking relief valve from hot water system 3Oct 03, 2019 12:02 pm chippy Have you tried opening it a few times. If a bit of scale gets stuck in the seat they series seem to leak a bit. If you open the valve a few times to flush it out I've found it helps. Hey chippy Thanks for the reply. To open the valve do you mean pulling that lever to drain water out...or actually dismantling it to open it apart? (Sorry i am completely useless with these things...am watching YouTube videos now to learn more) Re: Leaking relief valve from hot water system 4Oct 03, 2019 12:30 pm Just pull the lever. It should discharge hot water and flush the valve. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Leaking relief valve from hot water system 5Oct 04, 2019 9:47 am As he said. It can drip. Have they been yet ? DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6242 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 13643 |
