Browse Forums General Discussion 1 Sep 27, 2019 8:52 pm My house is on a steep block and is built on a combination of a concrete strip footings and brick piers. We've engaged the services of a structural engineer to remediate a subsiding pier as well as to address the obvious drainage issues under the house - when it rains water leeches out of the hill and streams through the subfloor area. The previous owners installed fans in the subfloor area in an effort to dry out the soil which is fine but does nothing to address the cause. The structural engineer has quoted almost 5k to rebuild the subsiding pier and footing and over 20k to design and build a proper drainage solution. The quote provides no detail about the solution nor does it provide a cost breakdown. Before I have a conversation about what exactly he plans to do I want to understand these problems are generally addressed. What do we need here? Presumably it's going to be some kind of trench at the back of the house to collect the water along with piping to carry the water to the stormwater drain. Also is 25k fair for this kind of work? Re: Drainage issues on a steep block 2Sep 28, 2019 8:12 am Welcome to the forum dgoloughlin My house is on a steep block and is built on a combination of a concrete strip footings and brick piers. We've engaged the services of a structural engineer to remediate a subsiding pier as well as to address the obvious drainage issues under the house - when it rains water leeches out of the hill and streams through the subfloor area. That's what you are required to do Structural repairs required certified engineering drawings as do works over $20K require a building permit, please check with your Council Building Department dgoloughlin The previous owners installed fans in the subfloor area in an effort to dry out the soil which is fine but does nothing to address the cause. The previous owners installed fans in the subfloor area in an effort to dry out the soil which is fine but does nothing to address the cause. You should have checked this out with a proper structural Inspection before you purchased the property prevention is always better than cure dgoloughlin The structural engineer has quoted almost 5k to rebuild the subsiding pier and footing and over 20k to design and build a proper drainage solution. The quote provides no detail about the solution nor does it provide a cost breakdown. Before I have a conversation about what exactly he plans to do I want to understand these problems are generally addressed. What do we need here? Presumably it's going to be some kind of trench at the back of the house to collect the water along with piping to carry the water to the stormwater drain. Also is 25k fair for this kind of work? You are correct in questioning what's being provided for $25K? I suggest you ask him to 1. Meet you on site, show you engineering details and explain the engineering repair work required in general terms 2. Separately, Pay him for the certified engineering drawings which needs to be submitted to the council sample pile drawings here Certified 2D Plans & Engineering Documentation 3. get 3 trade quotes for the works 4. Have the engineer inspect the work in progress if the engineer is separate to the contractor OT Quantities, are best produced and 2D details are best explained through 3D BIM Engineering Charged stormwater design sloping block Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Drainage issues on a steep block 3Sep 29, 2019 7:32 pm dgoloughlin My house is on a steep block and is built on a combination of a concrete strip footings and brick piers. We've engaged the services of a structural engineer to remediate a subsiding pier as well as to address the obvious drainage issues under the house - when it rains water leeches out of the hill and streams through the subfloor area. The previous owners installed fans in the subfloor area in an effort to dry out the soil which is fine but does nothing to address the cause. The structural engineer has quoted almost 5k to rebuild the subsiding pier and footing and over 20k to design and build a proper drainage solution. The quote provides no detail about the solution nor does it provide a cost breakdown. Before I have a conversation about what exactly he plans to do I want to understand these problems are generally addressed. What do we need here? Presumably it's going to be some kind of trench at the back of the house to collect the water along with piping to carry the water to the stormwater drain. Also is 25k fair for this kind of work? Really depends if the water source is surface, subsurface or a natural spring.I would get this investigated first before any design is done so this will require a soil test and probably some lab testing. Need more photos from around the house including your gutters. We have had 3 of the wettest years in a row for some time so that wouldn't be helping 3 6949 Hi there everyone i was hoping to get some details and some clarification on some potential defects that may have occurred our recent bathroom renovation. 1. There seems… 0 6968 Hi All It has been a few weeks since my last update. The build has been progressing well. No major issues to report. The scaffolding was dropped today, gyprock will be… 96 356973 |
