Any ideas on how to fix? If I mix up some mortar mix and try to smooth it out will it bond to the existing?
As the shed sits on the rebated edge it needs to be smooth. Slab is 2.46m x 2.46m and the shed is 2.36mx2.36m.
One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the…
Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and…
Thanks. Yeh ideally that would have been good, but have progressed too far now. Hoping some well placed internal walls fixed up into the battens will provide some…
