Good day. I would appreciate help to try identify source of noise. I am in the top floor of an apartment block, and have a thud (knock) noise, a very definite thud, no warning and no after shudder. Sounds like it's coming from junction between concrete roof slab, external wall and drop ceiling. Very localised. Definitely localised inside ceiling space as it is not muffled.
It happens almost every hour, sometimes up to 5 times in an hour, day and night. I have checked, there are no utilities in the area, no aircon ducts, water pipes or electrics. The only things I can identify in the area where the noise is coming from are 1) slip joint between slab and wall and 2) the steel u latice system used to suspend the ceiling from the slab.
When temperatures are consistent it appears to drop off. As soon as we have variability, it starts up. So one thing I have managed to narrow down, its temp variation related. There is no evidence of structural damage - cracks.
Possible causes.
1) can a flaw in a slip joint cause an instantaneous localised thud to occur with expansion and contraction of a slab, or
2) is it possible that some flaw in installation of the suspended ceiling brackets cause that noise when one has slab contraction or expansion, with the sound being amplified due to the ceiling cavity or
3) is there something else that could be the cause that I need to investigate
As the noise is a definite thud (knock) almost like a valve flap shutting, I would not have thought the slip joint would cause this, as far as the steel u-system is concerned, being steel I would have thought if it was that it would have a cluck noise, not a thud.
I am at a total loss, but need to solve as it is very intrusive.
Any ideas would be appreciated. I am hoping with some ideas I may be able to pin point the cause before I start cutting away ceiling to do detailed visual inspections. At this stage I am at such a loss, the only option I can think of is to open a man-hole and carry out visual observation of area in question.
