Browse Forums General Discussion 1 Aug 29, 2019 11:41 pm I have a bathroom (or an ensuite) with the central drain hole and an independent drain for the shower screen. A few pictures are here . It`s not too big area after shower screen, but this central drainage is as a barrier for any ideas... I wanted to do undertile heated floor, but it can be installed in a flat self-leveling screed. Moreover- I can`t use big size tiles. It would be ugly if I cut the central tile diagonally... May be we can do this floor flat if the shower has its own drain, please? What can tell experienced renovators/plumbers in this case??? Thank you Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 4468 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 18821 Hi, just need to ask if anyone build with Central Properties in Victoria. Thankd 0 4025 |
