Browse Forums General Discussion 1 Aug 27, 2019 11:46 pm Hi Everyone, I am just building my house, currently I am finalising the floor layout. I am planning to have double garage for new build. I am planning to convert double Garage to Living or sitting in future. Can someone please guide me what things I need to consider or add in garage during construction phase that will help me to convert it into living. Any modification needs to be done now to reduce the cost later or or anything which can't be done later. Thanks for your help. much appreciated. Re: Garage To Living room conversion 2Aug 28, 2019 8:19 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Allowing for future conversions is a good idea and can save you heaps later on. BTW, Most people still require a garage, adding a loft or studio apartment above is popular In sort after locations. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Garage To Living room conversion 3Aug 28, 2019 9:17 am 1) Usually the external garage walls are not insulated. You should have those insulated for use as living room. Even insulation for garage door, depending upon the direction. 2) Consider a higher garage entrance height. 3) Some modern garage door openers only have a small machine attached to wall near garage entrance. This takes away the ugly looking apparatus hanging in middle of the garage. 4) You will need more power points, data points, tv points 5) Appropriate window openings 6) Think about the roof access manhole location (if single level house) 7) Positioning for NBN box that usually goes inside the garage. Re: Garage To Living room conversion 4Aug 28, 2019 1:05 pm Your garage has to be designed and built as a habitable room. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Garage To Living room conversion 6Sep 01, 2019 8:44 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Heads Up, These are my Planning Drawing For a DA project in Perth Class A- Sand Soils, N1 wind load,etc,etc For reactive foundations ie Class S & M the masonry walls will require Reinforced Masonry Construction If you would like further Information, data and Costings leave a PM or email and I will start a separate post.You will also require a gmail account to access live project Data during the build Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Garage To Living room conversion 7Jan 15, 2020 9:30 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 11117 From the information posted it looks to me your rumpus room is nothing more than extended garage. That will present a number of challenges. Single brick wall between… 2 7759 Because it only states 90mm not if it’s 45mm or 35mm and yes I do have the plans my question was specifically since it’s not the structural value and only to hold… 2 3500 |
