Browse Forums General Discussion 1 Aug 10, 2019 3:20 pm Hi, a query I have with the power box location and what can be done? Thanks in advance for replying. the fuse / power box for the house was not placed as per the plans. And now the gas bottles are on the other side of house, which is harder to access. The original reason for location. Asked the builder and he just said easier ( or cheaper this way) and won't change. can they change the location with out our approval? What are my options as they won't change it. RBS says not his problem. Vic located. 2 7202 There is no reason why building contract reconciliation cannot be done prior to handover, if the builder won't do it get someone to do it for you. Why would you pay for… 3 6689 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28817 |
