Browse Forums General Discussion 1 Aug 08, 2019 4:08 pm Hi all, is it best to pain skirting and door frames first? If I can't do this does it matter? Also wondering how I should tackle the below, is some scraping and sanding enough to even everything out? I don't think it would be realistic to strip everything back but not sure? What would be the recommended grit for the sandpaper? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I am new to this forum so please bear with me. An NCAT order was breach by our neighbour regarding a retaining wall dispute. He is the owner of a building company and he… 0 2208 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6352 brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7575 |
