Browse Forums General Discussion Re: Clarendon left the power of my water tank to rain 2Aug 05, 2019 6:55 pm That's an outdoor power point. Note the inlets are facing down meaning gravity stops water from getting inside the PowerPoint. It's totally fine. Follow Our Clarendon - Double Gable, Hamptons Inspired Fairmont 35 https://forum.homeone.com.au/viewtopic.php?f=31&t=94604 Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1670 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3663 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 8070 |
