Browse Forums General Discussion 1 Aug 04, 2019 2:18 pm Hi all. We want to plaster our ceiling which has exposed beams. The house was built in 1976 and the floor to bottom of the beams is just under 2400. Does anyone know the minimum ceiling height requirements for a house built in 1976 in Victoria? Thanks Ben Re: Minimum ceiling height 2Aug 04, 2019 6:19 pm BennyG Hi all. We want to plaster our ceiling which has exposed beams. The house was built in 1976 and the floor to bottom of the beams is just under 2400. Does anyone know the minimum ceiling height requirements for a house built in 1976 in Victoria? Thanks Ben I don’t think it matters what the code was in 1976, because any changes would be governed by today’s codes. Australia wide: Quote: a room or space within a building must have sufficient height suitable for the intended function of that room or space. According to BCA Vol 2 part 3.8.2, for the requirement to be satisfied, the ceiling height must not be less than: * in a habitable room excluding a kitchen - 2.4 m * in a kitchen, laundry or the like - 2.1m * in a corridor or passageway or the like - 2.1m * in a bathroom, shower room, laundry, sanitary compartment, pantry, storeroom, garage, car parking area etc - 2.1m * in an attic, room with a sloping ceiling or projection below ceiling line or non-habitable room or similar - a height that does not unduly interfere with the proper functioning of the room or space. More than 50% of the ceiling space should be on average a minimum height. * in a stairway - 2.0m measured vertically above the nosing line. Otherwise, the room would be deemed to be a "utility room". However, if you have any doubts, best to contact your Council. Re: Minimum ceiling height 3Aug 04, 2019 6:39 pm arcadelt BennyG Hi all. We want to plaster our ceiling which has exposed beams. The house was built in 1976 and the floor to bottom of the beams is just under 2400. Does anyone know the minimum ceiling height requirements for a house built in 1976 in Victoria? Thanks Ben I don’t think it matters what the code was in 1976, because any changes would be governed by today’s codes. Australia wide: Quote: a room or space within a building must have sufficient height suitable for the intended function of that room or space. According to BCA Vol 2 part 3.8.2, for the requirement to be satisfied, the ceiling height must not be less than: * in a habitable room excluding a kitchen - 2.4 m * in a kitchen, laundry or the like - 2.1m * in a corridor or passageway or the like - 2.1m * in a bathroom, shower room, laundry, sanitary compartment, pantry, storeroom, garage, car parking area etc - 2.1m * in an attic, room with a sloping ceiling or projection below ceiling line or non-habitable room or similar - a height that does not unduly interfere with the proper functioning of the room or space. More than 50% of the ceiling space should be on average a minimum height. * in a stairway - 2.0m measured vertically above the nosing line. Otherwise, the room would be deemed to be a "utility room". However, if you have any doubts, best to contact your Council. Well that sucks... Thanks My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6931 Hi, only for walking. It is a narrow 1.5m paved area next to house. 2 5421 Thanks Draftroom that definitely helps a heap. We are still at the very early stage of planning to see what kind of house would fit on our plot. While we are on a… 3 15770 |
