Difference between site superviser and building inspector
Could anyone please clarify if site supervisor and building inspector are same?
Also there is involvement of building surveyors who issued building permit.
Are they all same?
Thank you
Are they all same?
Are they all same?
You need to post what State you are building when asking for advice but I have trawled through your other posts and found that you are building in Victoria.
The site supervisor is as per shokel1975's post but note that the site supervisor may not have any qualifications or at best, won't have qualifications in all of the trades he is checking. A site supervisor will rarely have just the one house to supervise, some have 20 or more.
In Victoria, the new home buyer or their agent must appoint the building surveyor. A builder cannot act as the buyer's agent.
A building surveyor will usually work with a less qualified building inspector who usually does most of the 'inspecting'.
If you are thinking of having private stage inspections, you would hire a building consultant who does stage inspections but you need to check their bona fides carefully.
Builder surveyor - as said must be appointed by you to sign off, but the builder may try and pressure you into using the one they recommend. May or may not do a good job but only checks a few things
Private building inspector - appointed by you to work on your behalf and check the quality of the work in a lot more detail than the surveyor. They will prepare reports, but are working for you and the builder is not answerable to them, and the builder may be very resistant to having one and addressing issues that they identify. Take this as a warning sign if they indicate this. Will cost around $5k over the build but worth every cent if you have a good one
Are they all same?
Are they all same?
yes in victoria
A registered building surveyor checks that work meets minimum building regulations, but does not check that the work:
meets the standard agreed in your contract
required by your contract has been completed.
You can engage an independent building consultant (what you are calling a private building inspector)to assess whether the work completed meets the requirements in your contract.
What building surveyors ‘inspect’ is limited. Often the actual surveyor doesn’t visit your house but sends independent inspectors on their behalf who pop in at each building stage.
Most builders will ‘encourage’ you to use their building surveyor. If you do so, they are not truly independent.
Site supervisors are really site project managers and book trades. Some have relevant trade skills and have/take the time to check some work. Many don’t.
An independent consultant/private building inspector as we call them in Victoria will check quality of work, that plans are met, floors are level, and that building standards are met. It is important to choose ‘an inspector’ with significant experience. I have friends who have said I can’t afford that.
I ask can you afford not to have independent inspections for one of the largest investments you will ever make. Rectifying poor building work is costly financially, and emotionally and can take years. Private inspections provide you information and peace of mind.
Anybody can provide a web link, phone etc?
Cheers
Thank you all for clarifying, please guide me to have reasonable inspector in victoria?
Check out building_expert who has a lot of qualifications and experience, he also gives a lot of advice on this forum.
Always ask for proof of qualifications and experience.
Profile: https://www.homeone.com.au/member/building-expert /
Website/Blog: https://www.buildingexpert.net.au/
Having read the post, I ask you guys, what companies in NSW can provide good building inspectors. I'm looking for a good one hopefully, one that someone as used or knows about it, I'm reluctant to pick one at random.
Cheers
Cheers
I was satisfied with housepect’s service in Sydney
In Victoria
David Seville - Seville inspect. I used this company and would highly recommend .
https://m.facebook.com/SevilleBQI/posts ... l&mt_nav=1
Seville Building Quality Inspections P/L
0488 993 332
Darbecca company that is very well known on forum
Building expert from this forum is also very thorough
I've compiled a list of Builder Inspectors and their contact details. I have not added any recommendations or review as I have no employed any of them, that will be up to people and their experience.
In my view, you should do all 4 inspections and a pre-signed contract. However, on the slab inspections, I believe it is better to do it before the concrete is poured as it will allow detecting and rectifying errors before it is too costly.
Cheers,
Victoria
https://m.facebook.com/pg/SevilleBQI/posts/
Ph: 0488 993 332
e: david@sevilleinspections.com.au
Darbecca
INDEPENDENT BUILDING QUALITY INSPECTIONS
Melbourne (03) 5367 2111
Queensland (07) 2101 5331
admin@darbecca.com.au
NSW
Building Expert
https://www.buildingexpert.net.au/about.htm
Branko Mladichek
Expert Property Reports
Building-Expert
Mobile 0400 021 711
HOUSPECT
https://www.houspect.com.au/about-page.html
20/14 Jubilee Ave, Warriewood NSW 2102
info.nsw@houspect.com.au
1300 258 789
QUEENSLAND
Darbecca
1
I would send it to the certifier who is technically your representative and working on your behalf not the builder's
23/02/2024
6
I do enjoy the drama:-D In his latest two videos he has started bringing security guards to site, I am waiting for the punch on to begin lol
15/02/2024
3
Adam Baines Grad Cert Bldg Surv / Grad Dip Bldg Surv / MSAAPA Accredited Building Professional APB20210035 Builders Lic 183023 Pest Control Lic 84868 Ph 0412202336 PO…
