Browse Forums General Discussion 1 Jul 15, 2019 5:50 pm Hi my house is 8 years old and was built in a factory and transported by truck to the site. THe house has vinyl cladding, when l removed a piece of vinyl cladding l was expecting to see plastic wrap around the plywood walls, but instead there was a thin layer of white polyester sheets covering the plywood. Is that OK and nothing to worry about or should they have put in plastic wrap Re: behind vinyl cladding 2Jul 16, 2019 6:05 pm I believe polyester can be used for things like insulation. But I'm not sure if that's the case in your house. Do you have pictures? Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 8049 Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8356 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15244 |
