Browse Forums General Discussion 1 Jul 13, 2019 8:41 pm Hey guys, Moved in a few months ago to a new house and have just noticed this crack above a sliding door that goes out to the alfresco. I don’t know much about builds - is this anything to be concerned about? Should I raise it in my 90 day follow up period with my builder? Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Crack above sliding door 2Jul 14, 2019 5:07 pm Raise all plaster cracks to builder at 90 day and then within 2 years of handover so they can be repaired and investigated if required. Look for settlement cracks in corners. Take lots of photos. Read the guide to standard and tolerances. You can download from VBA website . Read your warranty docs. Structural warranty is 10 years, the guide will let you know what is within tolerance. At your 90 day maintenance mention everything you notice. Start keeping a list. Many things you only notice when you move in. https://www.vba.vic.gov.au/__data/asset ... s-2015.pdf Most likely poor foam installation and render installation, Joint covered with render, foam could be sitting on flashing. Do you have any render at house 4 9317 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16161 |
