Browse Forums General Discussion 1 Jul 07, 2019 6:11 pm Hi, I have a question about my rain water system. Bought a new house, it has a wet system plumbed in but I notice the caps missing on the intake pipe into the water tank.(see attached photo) Is this normal? If so for what purpose if not I shall cap it off. Thanks in advance. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Rain water wet system intake question 2Jul 07, 2019 6:23 pm That is not normal, that is incompetence. Does the pipe go into the tank or just drain to the tank's top meshed inlet? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rain water wet system intake question 4Jul 07, 2019 8:47 pm Rainwater diverted to a storage tank has to pass through mosquito proof mesh, I hope that there is a suitable fitting on the downpipe. Maybe whoever plumbed it thought that the sealed pipe will have an air lock at the top of the vertical riser that would prevent water from flowing. If that was the case, fitting a meshed vent would have been much better than fitting a tee with the cap removed. Fitting an elbow and not the tee would have also provided a bit more head. Just cap it, caps with an O ring are available in the Bunnings plumbing section. I hope that there is there a flush valve/outlet on the wet system. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Rain water wet system intake question 5Jul 08, 2019 7:19 am SaveH2O Rainwater diverted to a storage tank has to pass through mosquito proof mesh, I hope that there is a suitable fitting on the downpipe. Maybe whoever plumbed it thought that the sealed pipe will have an air lock at the top of the vertical riser that would prevent water from flowing. If that was the case, fitting a meshed vent would have been much better than fitting a tee with the cap removed. Fitting an elbow and not the tee would have also provided a bit more head. Just cap it, caps with an O ring are available in the Bunnings plumbing section. I hope that there is there a flush valve/outlet on the wet system. Thanks for help, much appreciated Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1670 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14073 instantaneous is three phase and draws heaps of current, the efficiency comes from not storing it so you don’t lose heat to the environment. The problem is it is not… 5 1202 |
