Browse Forums General Discussion 1 Jul 02, 2019 12:41 pm Hey Guys Building a standalone townhouse with a small builder. I was wondering if I should get an inspection done at every stage? Is it worth doing? Which stages? I have been told by 3 inspection companies the various stages they could inspect are 1) Pre Slab 2) Post Slab 3) Frame Stage 4) Pre-Plaster Stage 5) Fixing Stage 6) Handover Stage Could you please recommend which stages to do if recommended? each stage is going to cost approx $450-500 with handover being above $600 so just trying to see budget and use. Builder is ok to get the inspections done so that / access is not an issue. I have got pre-handover stage done once for my previous house which seemed good. But this time I am thinking if I should do the same i.e. just the last stage or do more stages? Re: Build Inspection on every stage - worth it and which sta 2Jul 02, 2019 12:48 pm its Hey Guys Building a standalone townhouse with a small builder. I was wondering if I should get an inspection done at every stage? Is it worth doing? Which stages? I have been told by 3 inspection companies the various stages they could inspect are 1) Pre Slab 2) Post Slab 3) Frame Stage 4) Pre-Plaster Stage 5) Fixing Stage 6) Handover Stage Could you please recommend which stages to do if recommended? each stage is going to cost approx $450-500 with handover being above $600 so just trying to see budget and use. Builder is ok to get the inspections done so that / access is not an issue. I have got pre-handover stage done once for my previous house which seemed good. But this time I am thinking if I should do the same i.e. just the last stage or do more stages? Essentially you can combine stage 3 & 4. You want all your bracing and tie downs checked, but you also need to make sure that the i joists have been penetrated correctly during rough in. there is no reason why these cant be done at the same time to save money. But all the other stages are money well spent providing you have a good inspector Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Build Inspection on every stage - worth it and which sta 3Jul 02, 2019 5:25 pm I was told that Pre Slab might not be necessary too as that is done properly normally by engineers (or someone - can't remember) Was told to do the following 1) Post Slab 2) Frame Stage 3) Pre-Plaster Stage 4) Fixing Stage 5) Pre-Handover Stage An example: https://www.newhomeinspections.com.au/pricing/single-dwelling/ Suggests: Pre Slab, Frame, Pre-Plaster, Pre-Handover Another example: https://www.buywiseinspections.com.au/new-home-inspections Suggests: Pre-Plaster, Fixing Stage, Pre-Handover And then https://www.jimsbuildinginspections.com.au Suggests: All the above stages (1-5) Re: Build Inspection on every stage - worth it and which sta 4Jul 03, 2019 2:08 pm its I was told that Pre Slab might not be necessary too as that is done properly normally by engineers (or someone - can't remember) Pre slab is absolutely necessary, probably the most important in my opinion. Yes it is "checked" by the building surveyors inspector but I wouldn't trust that. If they were doing their job properly independent inspectors would never find anything, and yet they do. Our building surveyor's inspector must have been legally blind or didn't even bother to get out of the car. Our post slab was checked at frame stage. Re: Build Inspection on every stage - worth it and which sta 5Jul 03, 2019 2:20 pm its I was told that Pre Slab might not be necessary too as that is done properly normally by engineers (or someone - can't remember) Was told to do the following 1) Post Slab 2) Frame Stage 3) Pre-Plaster Stage 4) Fixing Stage 5) Pre-Handover Stage An example: https://www.newhomeinspections.com.au/pricing/single-dwelling/ Suggests: Pre Slab, Frame, Pre-Plaster, Pre-Handover Another example: https://www.buywiseinspections.com.au/new-home-inspections Suggests: Pre-Plaster, Fixing Stage, Pre-Handover And then https://www.jimsbuildinginspections.com.au Suggests: All the above stages (1-5) Pre slab is incredibly important as you need to check that termite collars are installed, sewer and drainage pipes are in the correct location and the specified reo has been used Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Build Inspection on every stage - worth it and which sta 7Jul 05, 2019 9:00 am Thanks guys.. I understand there is mixed reaction and both sides of the coins From the three links given above, could anyone recommend or list them on preference? Still trying to decide to go for, which stages and with whom? Re: Build Inspection on every stage - worth it and which sta 8Jul 14, 2019 5:30 pm Based on advice I had and my experience at minimum I’d recommend Pre slab!!!!!!! Very important but you do need to have someone who knows what they are doing. I’d worry about any service saying pre slab pour wasn’t important in Victoria at least where engineer does not come to site. As someone said above slab (post slab) can be inspected at frame stage as it’s visible. Frame stage Pre plaster PCI/pre handover (I would add an inspection at fixing stage if you were not confident that work was being rectified) Re: Build Inspection on every stage - worth it and which sta 9Jul 30, 2019 9:22 am Hi All I've read all the comments here, very valuables, I also believe that pre-slab inspections is vital as you can detect problems ahead of time and avoid expensive corrections. Now I have not been able to find a company in Sydney that offers that. Does anybody have a company in Sydney that does it? That will be of great help. Cheers Re: Build Inspection on every stage - worth it and which sta 10Aug 18, 2021 7:17 am malypetu Hi All I've read all the comments here, very valuables, I also believe that pre-slab inspections is vital as you can detect problems ahead of time and avoid expensive corrections. Now I have not been able to find a company in Sydney that offers that. Does anybody have a company in Sydney that does it? That will be of great help. Cheers hi , came across your post..hoping all went well in your home build...would you mind sharing whom you went with for stage inspections please?,would appreciate it much. cheers Re: Build Inspection on every stage - worth it and which sta 11Aug 21, 2021 6:52 pm Priority should be compaction and concrete specification compliance before, and a building perimeter compaction test / certificate after the roof goes on. Quite often the soil compaction is compromised by excavation by plumbers and electricians. An engineer can give you an "as constructed compaction certificate"which is good for court. Inspector reports do not hold the same water in court. Most houses today have the soil compaction damaged by machine excavation by plumber and electrician, post the initial compaction certificate. Nearly 100% of private home inspectors ignore the biggest cause of housing cracks. Compromised foundations. Compromised compaction is the biggest cause of cracks in houses, especially today where engineering has been extremely whittled down to reduce material costs. Its at the point where builders are cutting corners in the engineering, hence the huge increase in cracking in new houses. There are massive issues ongoing right now in new homes with cracks, where builder is blaming the land developer civil contractors, and the land developer civil contractors are blaming the builders. The engineering is not meeting the needs of these issues. As they say, "you are only as good as your foundations" *All in my opinion only Re: Build Inspection on every stage - worth it and which sta 12Aug 22, 2021 11:18 am alexp79 The absolute majority of building surveyor inspectors/certifiers are just a bunch of lazy clowns. Don't expect much from them. There are two issues here Firstly the entry level for building inspectors is a diploma of building surveying plus experience of working in building surveyors office. That is fine for mandatory inspections but many have never built anything, don't know about contractual matters, have not inspected existing homes to know how building elements fail, nor do they care about contract conformance. Contract that against a good building consultant that has higher tertiary qualifications, a lifetime of building and inspecting and yes there is the difference. The second issue is that mandatory inspectors get paid around $120 and produce one page checklist. A building consultant will charge around $600 and will give you a verbal summary on the day followed by a report of findings, experience opinion and recommendations, and in addition you can ask questions about your contract or building issues on the day. Sure there are lazy clowns but many are competent mandatory inspectors that do a good job, however it is in a limited sub set of competence. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog 4 6831 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73510 Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14449 |
