Browse Forums General Discussion Re: Bathroom renovation 3Jul 01, 2019 3:38 pm We have a tiler to do the tiling but he doesn't render or plasterboard. The tiler said to call him when ready for tiling. Everyone tells me something different so hoping to find out the correct process etc. on this chat before proceeding. Re: Bathroom renovation 4Aug 04, 2020 2:41 pm Hey Tazw, Always do the modifications first prior to finishing the walls so go ahead and do the window first in case of damages to walls. This includes if you need to change any electrical or plumbing works in walls. If you want to use sheeting on the walls you will still need to remove the render that is loose and you will need to batten the wall prior to sheeting to make sure they are true and plumb (More work, More Money) I would just remove all loose and drummy render and hire a cement renderer to redo the walls, best to get experienced tradie as this is the main substrate you are tiling on top of. Re: Bathroom renovation 5Aug 04, 2020 6:19 pm Splashers Hey Tazw, Always do the modifications first prior to finishing the walls so go ahead and do the window first in case of damages to walls. This includes if you need to change any electrical or plumbing works in walls. If you want to use sheeting on the walls you will still need to remove the render that is loose and you will need to batten the wall prior to sheeting to make sure they are true and plumb (More work, More Money) I would just remove all loose and drummy render and hire a cement renderer to redo the walls, best to get experienced tradie as this is the main substrate you are tiling on top of. Thank you Splashers. All done now and we did exactly what you recommended. I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 9872 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11228 Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5450 |
