Browse Forums General Discussion 1 Jun 18, 2019 7:09 pm Owner builder: What should I insulate the subfloor with. The joists are C-section on RHS Bearers. The floor will be hebel AAC. Was looking at green foilboard as I don't like fibre insulation as it is a mouse attractant. Also is condensation an issue as foilboard is non permeable, or do I go with something like AIR CELL permifloor draped over the bearers so I can glue the hebel to the joists?The subfloor will be 2.4m off the ground so I want it to look ok, and we have BAL 29. Do I do something and then sheet with cement board? Re: Insulation for subfloor in unenclosed steel framed house 2Jun 19, 2019 8:20 am You will need to refer that back to your structural engineer as that is a structural floor The Building Surveyor & Council that certified/approved the plans should have advised you accordingly. OT, if it is incorrect your Home Insurance policy may become void. hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Insulation for subfloor in unenclosed steel framed house 3Jun 24, 2019 11:13 am tolisawiro Owner builder: What should I insulate the subfloor with. The joists are C-section on RHS Bearers. The floor will be hebel AAC. Was looking at green foilboard as I don't like fibre insulation as it is a mouse attractant. Also is condensation an issue as foilboard is non permeable, or do I go with something like AIR CELL permifloor draped over the bearers so I can glue the hebel to the joists?The subfloor will be 2.4m off the ground so I want it to look ok, and we have BAL 29. Do I do something and then sheet with cement board? Do some research on how they do it across the ditch. I personally feel that their building standards are a lot better than ours. They build a lot of timber homes set on bearers and joists and they lay a plastic membrane over the ground to stop moisture rising and then use Styrofoam between the joists Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Insulation for subfloor in unenclosed steel framed house 4Jun 24, 2019 8:35 pm SejaeD tolisawiro Owner builder: What should I insulate the subfloor with. The joists are C-section on RHS Bearers. The floor will be hebel AAC. Was looking at green foilboard as I don't like fibre insulation as it is a mouse attractant. Also is condensation an issue as foilboard is non permeable, or do I go with something like AIR CELL permifloor draped over the bearers so I can glue the hebel to the joists?The subfloor will be 2.4m off the ground so I want it to look ok, and we have BAL 29. Do I do something and then sheet with cement board? Do some research on how they do it across the ditch. I personally feel that their building standards are a lot better than ours. They build a lot of timber homes set on bearers and joists and they lay a plastic membrane over the ground to stop moisture rising and then use Styrofoam between the joists Thanks will have a look Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14389 Jimbo73 I would use heaps of adhesive on each sheet and screw rather than nail. use as many as you like cheers Simeon 1 4043 XCEM Alpha flooring seems to relatively new and I could not found any reviews. Have you or someone you know have used it and would recommend over other subfloor options?… 2 7556 |
