Browse Forums General Discussion 1 Jun 15, 2019 11:25 pm Does anyone know how high concrete footings need to be above ground for aluminum patio/pergola posts? Initially the company we had build our patio left the footings approximately 200mm below ground. Council final inspection didn't pass as they are saying they want it no less than 100mm above ground. Yet the council have written in the report steel posts. Ours are aluminum. A magnet wont stick to aluminum which we have tried. Can anyone please shed some light as to which is correct. 100mm above ground will make our pavers very high above ground level. Plus then we would need to remove gutter down pipes and reconfigure those plus drains. What was supposed to be a simple install is turning into a nightmare. Thank you in advance. Re: Concrete Footings for patio/pergola 2Jun 16, 2019 6:58 am Hi Bazinga2019 Welcome o the forum Do you have the engineering drawings for the installation? Did you get Council approval for the installation? More info required and please put up a photo Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely. 6 16147 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7789 If your patio is going to be 35 sqm then that's going to need Council Approval. The fact that they previously approved your 25sqm patio will be irelevant 1 5507 |
