Browse Forums General Discussion Re: Builder Illegally Using and Damaging Property 2May 27, 2019 1:47 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Builder Illegally Using and Damaging Property 4May 27, 2019 5:12 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Builder Illegally Using and Damaging Property 6May 28, 2019 8:45 am Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Builder Illegally Using and Damaging Property 8May 28, 2019 1:10 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Builder Illegally Using and Damaging Property 11Jun 03, 2019 5:38 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Builder Illegally Using and Damaging Property 18Jun 16, 2019 3:25 pm Why didn't you follow SejaeD's advice? 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Builder Illegally Using and Damaging Property 19Jun 17, 2019 7:47 am SaveH2O Why didn't you follow SejaeD's advice? Yes, I have spoken to home building advocacy and seeing a solicitor as well. Not sure what will be the legal fee to deal with this. At the same time, i have pushed back all excess landfill back to his property with some cost. Re: Builder Illegally Using and Damaging Property 20Jun 17, 2019 9:37 am SejaeD You are simply not allowed to transport soil from one site to another site without having it validated first. This involves having it tested in a laboratory to determine whether or not it is VENM or ENM. This costs thousands of dollars. And then you need a certificate stamped as the truck leaves your property and you need it certified that it has reached the nominated destination to stop illegal dumping. Hi Dharma, I was referring to SajeaD's info posted as above. I thought that it was very good advice and worthwhile following up. Just surprised that you didn't respond to him. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. 0 2020 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16148 Hi Mofflepop, I would recommend finding a building designer to prepare plans, they should design to your specified budget. The benefit is you can tender the project out… 9 20420 |
