Digging under house slab
I was wondering if someone could give me advice around digging up to my house slab on a timber frame house. Both perpendicular walls have footings and brick cladding 2 stories but the one against where I would like to dig is just the slab with timber frame on top
If I'm to dig up quite close to it, approximately 2 meters down will this cause any issues? I'm aware of the zone of influence in regard to the footings and brick on the other sides but have not yet found anything in regard to the wall where I would like to dig
I am looking to install a pond / pool on this side as a DIY project
Thanks in advance and happy building
Your timber frame and slab would have to sit on top of some form of footing.
Draw a 45 degree line down from the bottom of your footings and if your excavation gets on its way, you would need to involve structural engineer who would provide a design for how you would need to retain your excavation.
You must be careful when you say this as it is not the case for sand.You will need to know the depth of the slab and the soil type.
Apologies, agree, this approach generally applies for the clay soils.
In any case, it is always best to involve professional structural engineer for the advice.
Massive excavation near the footings is something which always needs to be double checked.
You will need a building permit if your pool holds more than 300mm of water, it will be deemed a child drowning risk and pool fencing will be required.
Not if its a 'natural pool', it can be classified as a pond and the rules are grey. 300mm Rule only applies to pools and spas apparently.
6
Thanks for the insights, that makes perfect sense, and yeah, I will be leaning on the experience of the excavator operator entirely.
5/03/2024
4
To me, that's what it looks like: poor backfilling and/or compaction. The width is about 1000mm maybe. That conduit in the photo is for the NBN. The water is about…
