Please help the community by reporting Spam
What every house needs.
Ha ha ha ha,yes if Cancer is your wish.
Do you guys know how to report spam?
There are 3 dots at the bottom right hand corner. Clicking them will bring up a menu, just click on Report Post and a box will appear that allows you to report the post and the reason why.
It often takes the mods hours if not days to remove it so was just having a laff.
Thanks though.
Yes I know how to report spam and do so regularly.
It all helps.
You have to shake your head (and maybe laugh) at some of the persistent ones, fake university degrees, fake passports and fake currency come up regularly.
I love how Homeone changed this thread's title.
This is Joshua the programmer for homeone.
For tapatalk, to report a post on iOS you can tap the post and select 'Report'
On Android it should be similar, tap a post to select it and then pick the three dots at the top right of the screen (...) and select 'Report'
4
I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more…
8/06/2023
2
Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀
20/09/2023
7
i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one…
