Browse Forums General Discussion 1 Apr 26, 2019 11:45 am We live on the West coast where severe winter storms and strong wind and rain is common. Over the past few years, water has been leaking into the second storey brick cavity and getting into the house, wetting the carpets and damaging the hard plastered walls. The water is definitely not getting into through the roof (flat Colourbond with flashed parapet walls) as there is no damage to the ceilings. We have tried everything to stop the leaks but have been unable to find the source. I should mention that there are rollershutters installed which stop the rain hitting the windows and doors. Has anybody had a similar problem and managed to solve it? Re: Leaking walls 2Apr 26, 2019 7:48 pm You could try application of clear waterproofer on the brickwork Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Leaking walls 3Apr 27, 2019 8:12 am building-expert You could try application of clear waterproofer on the brickwork OK thanks for that. The walls are painted with two coats of a good quality acrylic paint but I will check to see if it's possible to paint the waterproofer over the paint and then apply another coat of paint over the top of that. DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24148 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6066 The spacing of the studs looks pretty large especially for a load bearing wall. 3 11124 |
