Browse Forums General Discussion 1 Feb 16, 2019 6:38 am Hey all, Recently built a house with a good sized alfresco area. We intentionally left part of the alfresco uncovered as a bbq area/outdoor kitchen but wanted to put a glass balustrade around the whole alfresco as it is elevated. This would mean the balustrade would run right behind the outdoor kitchen. Any issues with running a glass balustrade right behind the outdoor kitchen? Some glass balustrades have exploded in heat (the 40+ Degrees days) so was curious if anyone has a similar setup and has any issues. Thanks Re: Outdoor Kitchen & Glass Balcony 2Feb 16, 2019 7:25 am Hi esanto1 I would pick a BBQ on wheels that could be moved away from potentially troublesome Building Materials Such as Glass, SIP and PE filled materials. Apart from shattering you don't want to burn your house or apartment down Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Outdoor Kitchen & Glass Balcony 3Feb 16, 2019 7:39 am Not sure one on wheels is an option as my wife has her sights set on a particular outdoor kitchen. That being the case, maybe we should just stop the glass at each side of the countertop rather than go behind it. There would be at least a foot clearance between the bbq and then the glass if we did that. Re: Outdoor Kitchen & Glass Balcony 4Apr 21, 2019 8:50 pm you could always put screens either side of the kitchen as a feature instead of the panels saving having to put the panels behind the kitchen.. all depends on how you are making the kitchen? ie do you ever want to be able to get behind it etc First time building 2 storey home in NSW. Below Current plan have separate balcony. But thinking to do a multipurpose lounge with balcony (kind of sunroom) in first floor… 0 5052 Well you won't get cooked by the afternoon sun when sitting out on the balcony on a summers afternoon but you won't have much to look at besides the neighbours… 4 4127 Dear all, Requesting your help in relation to a CDC code. We are building a new home in NSW on a corner lot (500m2, 15m wide) following Greenfield CDC code. Our design… 0 6612 |
